noodle
Hi - Need the team's help. New to solar setup and I'm not getting my expected output.
Setup -
Panels: 4 x 100W panels - Volts 17.1; Amps 5.9
Connectors: Parallel using bougeRV 1to4 connector (which says its cable size is 10-14 AWG)
Cables: Cable to inverter is iGreely 20 feet 10AWG cable
Inverter: Inverter is solarepic grid tie inverter (600W-18V) [it says the input is range of 11-32 VDC)
Angle: Panels are at 30% angle.
My theoretical math is 17.1 volts x 23.6 amps = 403 Watts
My max measure output is 210 (sunny day in texas); not anything close to 400 Watts.
I measured the open circuit amps and volts per panel and they are all good.
I measured input voltage at the inverter and its not to much of a drop.
I can't measure amps at the inverter since my multimeter only goes up to 10 amps.
I know the low voltage and 20 foot distance will lose some power but does it seem reasonable that I'm only getting 210 watts at my peak ?
Setup -
