MakeMePower
- Oct 11, 2021
- 55
You may need a newer version of the app. I know I had to get a newer version of the PC software to set some of the settings for the 150 amp model.
Finally got it all working, it works well although it stops discharging if the charging is disabled. That's a shame really as there's buttons for both in the app
So I understand this correctly, the battery will disconnect at the under temp? in discharge mode? that makes no sense, should be the cutout temp.
discharge shouldn't matter, I thought @DJSmiley confirmed nothing happened, only special things happen at charge, not discharge
