I have a new JBD-AP20S003 BMS (7S-20S) connected to 16 new LiFePO4 batteries for a 48volt system.
The BMS App is reporting 18 cells instead of 16.
The BMS App reports the first 15 cells have nominal voltage of 3.3 volts, similar to what my multi-meter reports.
The BMS App reports the 16th cell as 2.7 volts, but my multi-meter reports 3.3
The BMS App reports the phantom 17th and 18th cells as 0 and 0.3 volts respectively.
Troubleshooting steps so far.
Ensured all of the nuts are tight on the batteries.
Verified that the wires are all connected correctly.
Verified that the last 4 unused balance leads are not open.
Anything else someone can recommend?
