I just got a pair of JK-B2A24S-20P bms’s. They will be replacing a single 300amp Daly. The inverters have a 200 amp breaker on each branch from a buss. Now I’ll have two batteries and I want to breaker each to protect each and/or to take off line. I realize that each bms is rated 200 continuous but……. what do they really handle.
And where does a breaker actually trip and how long till it does. Or just go with a 200 breakers and put my values in the app settings and not over think it. I know Andy used only 100 amps on his, but that’s on the light side for me. As you can see in the screen grab of the last month, I don’t use a lot of amps 99% of the time but it’s nice to have it available if someone turns on the dryer and AC at the same time which we have avoided up to now.
Two breakers I’ve been looking at are the DIHOOL 160 or 200 amp single pole
