manjulabw New Member Joined Jul 18, 2022 Messages 14 Nov 29, 2022 #1 Hi, i got abnormal error on jk bms after 9 day of usage. suddenly it shows 236 cycle but it was only 3. need your advice fix the error.
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 19,720 Nov 29, 2022 #2 Never seen that happen before. Hopefully someone else has.
manjulabw New Member Joined Jul 18, 2022 Messages 14 Dec 2, 2022 #3 timselectric said: Never seen that happen before. Hopefully someone else has. Click to expand... if anyone knows bms reset procedure please let me knw
C cityel.uk New Member Joined Feb 5, 2022 Messages 18 Jan 24, 2023 #4 Same issue here. Any news on this?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 19,720 Jan 24, 2023 #5 If you change the capacity, the cycles will reset. It thinks that you put it on a different battery.
C cityel.uk New Member Joined Feb 5, 2022 Messages 18 Jan 24, 2023 #6 timselectric said: If you change the capacity, the cycles will reset. It thinks that you put it on a different battery. Click to expand... Very clever, thanks! Will try that later today and report back.
C cityel.uk New Member Joined Feb 5, 2022 Messages 18 Jan 25, 2023 #7 timselectric said: If you change the capacity, the cycles will reset. It thinks that you put it on a different battery. Click to expand... Absolute start - this sorted it! Thank you so much for sharing!
