LouFromDetroit
Hi All, long time lurker first time poster.
I just wanted to share the NTC Temp sensor connector type for the JK B1A8S20P BMS and B2A8S20P BMS.
I spent a lot of time looking and finally stumbled upon the right type. I wanted to build an extension and did not want to cut and splice. I could not find the specs anywhere. Also it seems JK uses different connector on the silver vs black BMS.
HY2.0 2.0mm Wire Cable Connector Plug Male & Female Battery
Hope that helps someone.
