I use the new JK bms on my diy battery in combination with a Growatt sph 4000.
If I set the bms to the growatt protocol, the inverter charges the battery with intermitting amps, fro 00 to 10A within 1 or 2 seconds.
If I set the protocol to Pylontech, the charge is no problem, but the inverter does not increase the SOC. When the battery is fully charged and I set the protocol back to Growatt, the SOC is back to 100%. The next day then the charging is a problem again and I have to put it back to Pylontech to get it charged.
The firmware on the BMS was 15.17, but I downgraded to 15.11 to see if the problem was solved, but it was not. Maybe there is someone who knows a solution for this problem.
