JK (JiKong) RS485 interface wiring
JanVJ
Norway
My JK RS485 got chineese letters to identify colors for A and B.
Looks like JK made two different covers for the RS485 interface
I used Google Translate to identify the colors.
Since the result from Google is the same as the english version of the interface I will use this.
Hope this could be useful for others.
JanVJ
Norway
Saturday morning in rainy northern Europe;
I was going to do some testing;
On the table I got my 200 amp
JK (JiKong) B2A8S20P BMS
I was going to hook up my RS485 interface.
The interface comes with a 4 pin plug,
This BMS port labeled RS485 is a 3 pin port,
Next to the RS485 port there is a 4 pin port labeled GPS,
The datasheet give a lot of info;
Also the following text;
GPS (optional) Support (GPS or 485 just choose one)
Other interfaces (customized) RS485/CAN
I also got a interface that suppose to be a CAN interface. This interface also got a 4 pin plug.
My question; Would the 4 pin port labeled GPS also be the port for my 4 pin RS485 interface?
Why sell a bms with a 3 pin RS485 port, and interfaces with 4 pin plugs….. Just to confuse me 🤔
Anyone?
Yeah… maybe I need to ask the seller in China 🙄
upnorthandpersonal
Administrator
Staff member
Moderator
63° North, Finland
Does the RS485 socekt provied native RS485 or do I always have to use the RS485 Adapter from JKBMS?
It's just UART/TTL - so you don't need the adapter, just a TTL/USB adapter will do. Pinout is on my Github here in the readme:
