I am planning replacing bad Trojan T105 batteries in my RV. I am starting with 8 GC2 Trojans with 2 Magnasine MS2812 inverters. If I was starting from scratch I would go to higher than the 12V system but that would not fit with everything allready built for 12V.
The MS2812 inverters and handle quite a bit of amperage and that is my dilemma. Continous it will take 234 Amps and up to 325 Amps on a surge. I'm on a budget and it's getting streched. Building my own I would go with the group buy 280Ah cells. If I use a 2P4S configuration that would give me 12V 560Ah but what do I use as a BMS. Daly has one that goes to 200-300Amps but no temp sensors. I like the ones at Overkill Solar but they are 120 Amps. I could go with 2 4S configuration with the BMS and then put these in parallel.
I'm looking for suggestions and recs on what else I'd need. If I go with the overkill BMS can I get away with using the bluetooth app or do I need to build in a monitoring system?
My wife wants me to get a plug and play set up and I like the BigBattery 12V 170Ah powervault as it is essentially the same size as the T105's but 4 of them is over budget and 2 of them isn't enough.
