the.harold.c
- Feb 18, 2021
- 4
I finally decided to pull the trigger on a mini-split for my detached garage. This forum has been instrumental in helping me decide on the EG4, and for helping me work up the courage to do it on my own. I’ll be adding some panels this spring!
(*mine included the template to drill the line-set hole - thanks Will! )
Thanks everyone!
*I’ve only just begun to wall-out the inside of the building. I put those initial plywood panels up first (over the foam-board insulation) just to facilitate the install. (The inside unit is mounted to a horizontal 2x12 running between the 2 vertical metal posts) I’m going to eventually cover the seams, hardy-board style with some 1x4 trim boards, etc..
Thanks everyone!
