dlowery808
Hello All,
I have 4 HLX1800 V3 12v 150ah LiFePo4 batteries. Recently one has started misbehaving. When checked with the KiloVault Bluetooth app, it shows a voltage of 13.4 volts. When checked with a multi-meter it only shows 12.88 volts. I have the ability in the app to see the mv of each cell and they are in line with the voltage the BMS is stating. I'm just trying to figure out why the voltage at the terminals is so low/different. Also, the BMS won't allow any further charging to reach the 14.1 volts that is recommended by KiloVault
I have tried several 12 volt things/tools to create a current draw to see if that might wake the BMS up and fly right, but no joy.
Thanks!
Thanks!
