Hello everyone, wanted to get some advice to understand if there is an issue with my setup...
I have a Growatt 3000-S inverter, connected to 10x 285W solar panels. The system is performing pretty well, while orientation could be better (it is SE) my roof does not have any shades and has a good angle.
What I`ve noticed, I`m running pretty far from the peak performance. Typically on a hot day I max out around 2200 Wh, colder days slightly higher. See an example from the past days (was around 15C, so not really a HOT day)
However, when some clouds comes in for a short period, - and assuming that cools down the panels even for just a few minutes - it goes up easily to the peak performance, however it does not sustain it for long. It went up to 2800 below and after the next cloud it went back again above 2500.
I understand panel`s performance will drop with higher temperature, however wondering this level is justified what I`m observing? It is still around 15C with some nice wind and the panels performs below 80%. The product sheet does not indicate this high of temp coeff.
Could there be an issue with just 1 panel which overheats and draws back the whole system? Anything worth to check?
Thanks in advance,
Thanks in advance,
