Leak in solar hot water panel
evad
I have a solar water heating panel which developed a leak when it froze. The leak is small and at a solder joint. I can solder it but it will be difficult. Has anyone one had good results with a epoxy or other coating. The water pressure is about 75 lbs. Any information will be appreciated.
I would give it a shot. If you can pull it apart, sand it clean then flux and solder, do it. If the solder doesn’t take right away try 50/50 lead solder, it’s much easier to solder with. I would try soldering before epoxy etc.
You have to solder it and even then since it froze more than likely it is toast, been through this and never will use thermal solar again.
