NZ12VOLT
Wow great info here ,mind boggling
Not sure on wording but got some cheap solar panels as pic shows 12volt 10 watt .83amps ( low) ..I'm running 3x12v panels wired in PARALLEL running into 30amp PWM solar controller into 12volt car battery with a 600w power inverter to run 42' TV in a caravan instead of 240 mains power
Everything works great when the suns out but clouds seems to trigger low voltage alert on the inverter at 10.8volts so I turn off to let batt charge up again which is pretty quick but annoying.Also running led lights through the dimmer
I understand my input is lacking on the amps side but wondering if I can again boost the system using 2x10amp controllers which I have to maybe increase charging input from the solar controller to the battery to keep up with the load or do I just need a better wattage panel.
Thanks for any advice on my budget system
I have read this 2 solar controller set up works better than just 1 controller but asking the gurus here before I get screwdrivers out
