Anyone here has this infamous LED flicker with XW Pro? That's my third inverter. First two are EG4 6500x and SunGoldPower LF 6000w/48V.
I see about the same level of flickering with 6500x and XW Pro. I got XW Pro few weeks ago from Signature Solar. Don't have InsightHome yet, so don't even know what firmware it's running. I assume not very recent. 6500x is on the recent (or almost recent) firmware. Of course not all LEDs flicker but those that flicker with EG4 seems to continue to flicker with XW Pro. Although I have one LED on dimmer (the only dimmer I have in a house) which flicker the less on XW Pro compared to other two! Now, SunGoldPower has the least flickering IMO on same LEDs compared to others (except for the only light that's on dimmer).
I was really hoping that XW Pro will be as close to grid as possible (that's what Signature Solar owner said in one of his recent videos!). And it's great in general except for the transformer noise and this flicker issue.
I hope the flickering issue will be less when I get my InsightHome and use the latest firmware.
Idle consumption: EG4 6500x and SunGoldPower LF - both ~100W idle. XW Pro - somewhere between 25W and 30W. Huge win for XW Pro here if you don't have massive system with lots of PV and batteries. Also EMI is quite low for XW Pro. On opposite it's super high for SunGoldPower and that's one of the reasons I decided to go with XW Pro. Power wise SunGoldPower was fine for my purposes.
Thank you!
Thank you!
