Thanks for chiming in.
Yes, buying a quality fuse from a reputable supplier is the safest bet. However, at the very least I'd like to verify and know for sure that a certain fuse type will work in case of a fault in the system.
Agreed. You've made a valid point that even if the test is successful, by placing a new fuse that is untested there is no guarantee it will work as the one used in the test. But at least I'll know this particular fuse is suitable for the application.
It would suck if the test would end up damaging the BMS or the battery cells, but the BMS should be able to disconnect the battery in case of a short circuit, right?
If anything, to begin with, I could at least test the fuse AIC with a single 3.2V LFP cell, and if it doesn't work at least I've limited the damage to a single LFP cell.
IIRC V/R=I, meaning 3.2/1.8miliohm = 2064A which is way above the fuse rating and should blow the fuse.
The part I'm having difficulty understanding currently is how big of a difference voltage makes in testing if the fuse will manage to break the circuit in a fault event.
LE: i.e. is it necessary to test the fuse with a 48V battery as well just to be certain the fuse will work?
