We have 16 cells (8S + 2 x 4S) which were not top balanced prior to use. We plan to work first with the 24V cells (injured). This way we can make use of the 12V batteries to operate our 12V appliances while we try to revive the injured cells. Once we had a practice run with the injured cells, then we may attempt to top balance the 12V battery cells, assuming that is recommended.
When I top balance these injured cells, in which way should I balance differently compared with when you are balancing a new set of healthy cells? We read a good pdf from here:
https://diysolarforum.com/resources...ls-using-a-low-cost-benchtop-power-supply.65/ I would like to know how to tweak the procedure for injured cells.
I found this post (
https://diysolarforum.com/threads/strange-issue-with-48v-lifepo4-system.49308/page-2#post-628805). I also found a YouTuber charging at 0.1A or something, so we hope starting to charge at 10A is ok in our case.
This is our plan: Using an example of the voltages from the time we took a video:
2.664V
2.625
1.921
0.660 – will not attempt.
2.649
2.652
2.660
2.728
We will start charging the second lowest voltage cell (1.921V) first at 3.000V and 10A to bring it up to the highest voltage (2.728V) of the pack. Repeat the process to make all cells ~ 2.728V.
Then connect the 7 cells in series and charge at 21V (3V x 7) and 10A, with a 6-21S LiFePO4 BMS. Gradually increase the voltage by 0.7V (0.1V x 7) , up to 25.2V (3.6V x 7). When the voltage reaches the minimum for balancing to turn on (3.350V per cell min., per the 4s manual), the BMS will automate the balancing process.
1) I think the instructions from Steve S (see the second link above) introduce connecting cells & BMS much later. Let me know if my plan sounds safe enough.
2) Does anyone know of other step-by-step instructions (links / videos) to revive injured cells?
Thanks.
