"Shim-cells". Small cells used in parallel to match a cells capacity with peers.
I have a lower capacity cell. It's the first down and the first up and over voltage.
It actually seems quite difficult and quite expensive to buy small cylindrical LFP cells.
I do have a "clatter" of LiIon 18650s.
Why can't this work?
The range I operate my LFP in, per cell, 3.65V to about 3.00V, is voltage compatible. I might only get about 50% capacity on the LiIon cell at 3.65V, but I think I only need 2-5Ah of shim.
Current wise, a 3Ah cell in parallel with a 90Ah, will be "fine!".
Is there anything I am missing before I put an 18650 2.9-4.2V in parallel with an LFP, just to add 1 or 2 Ah of capacity?
Also... any suggestions on a UK source for "tiny" LFP cells?
