Last night, I was in my Van doing some measurements to rebuild the wooden interior, when I heard a silent "poof" followed by a hissing sound and a really bad smell. It was dark already, I checked around and I see flames under the seat where my second bigger set (320Ah) of LiFePo4 batteries was set. Luckily I had a small fire extinguisher at hand so I took it out quite fast. I called the professional who did the installment and he came rushing to my place so we took the battery out.
So what happened? The car was not running, as it is charged only through the car engine. There was no load on it. It was spontaneous.
The wiring was done correctly and the battery supposedly short-circuited inside the cell. The funny thing is, while it was still assembled after I took out the fire, the BMS showed no problems.
This event makes me a bit confused and worried, as I was sure LiFePo4 is safer against fire and with no overcharge (the setting on BMS was way lower to have more cycles).
I went back to the computer to check the store I bought the battery from (AliXpress) and the store doesn't exist anymore (after less than a year).
Not sure what the outcome is, and what I learned, except to maybe buy more expensive stuff, but what I also know, is the more expensive stuff doesn't mean it is guaranteed safer.
Damn.
Damn.
