Zwy
Emperor Of Solar
We are referring to a 0.6V increase in voltage for a 12V nominal system, 1.2V for a 24V nominal system, not running say a 12V nominal motor on 24V or a 24V nominal motor on 48V."An assumption people often make is that since low voltage increases the amperage draw on motors, then high voltage must reduce the amperage draw and heating of the motor. This is not the case. High voltage on a motor tends to push the magnetic portion of the motor into saturation. This causes the motor to draw excessive current in an effort to magnetize the iron beyond the point where magnetizing is practical."
Attempts to "win" an argument by cherry picking out of context is not the answer.
This is correct and what I referred to, you finally admit you were wrong to begin with. Go back and read what I posted, the words "watts are what make horsepower. If you increase voltage, the motor uses less amps for a given load.""The current a motor will see, is directly related to the load. As the load of a motor increases the amount of current also increases. Current is what contributes to heat. As current increases the heat built up in the motor also increases."
The trolling motor will use X number of watts to propel the boat for the given load whether it has a FLA, AGM or LFP battery.
