metalheaddoc
What are the load terminals actually useful for on an SCC? Most of the info I have seen says the not use them. I guess my question is why are the even there if most authorities say don't bother using them.
Because they look like a good idea for those who don't know better.What are the load terminals actually useful for on an SCC? Most of the info I have seen says the not use them. I guess my question is why are the even there if most authorities say don't bother using them.
I use mine for the lights in the utility room. They're on a motion detector so when I get to camp late at night I can see to turn on the main array and dig out the generator and cord without tripping over stuff.What are the load terminals actually useful for on an SCC? Most of the info I have seen says the not use them. I guess my question is why are the even there if most authorities say don't bother using them.
Anything automotive, RV, and some Marine will al be based on 12v DC and usable. The big one is to find out what the maximum amperage draw of those ports is and not exceed that.Is there any easy way to find products to go on those terminals? I may just not know where to look. Or, are people essentially making custom lighting. E.g., I'm a bit new to the game, and I can't seem to easily find "12 V lighting". I was thinking of buying a 12 V auto socket with wires, and just wiring that in, because then I could use automotive stuff.
Did you wire these yourself? E.g., get a 12V socket with leads and wire it in?There are 12V LED bulbs that are quite bright. I have lots. My house is 24V, so I use them "in pairs".
Now, those Load ports usually have a light bulb as a symbol, right?
That's just about all they're good for, connecting a LED bulb to them ;·)
Instead of connecting a socket to the lead screws and then putting a plug on your 12v Thing, just put the wires from the 12v Thing into the screw terminals.Did you wire these yourself? E.g., get a 12V socket with leads and wire it in?
