Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,804
Generator is much more expensive to operate, and bother.
If grid less than completely reliable, then inverter, batteries, PV can provide backup.
PV can be significantly less expensive than grid. At least the panels; balance of system can get expensive.
Inverter systems may actually be less reliable than grid, and don't have a crew backing them. It is good to have a bypass mechanism (transfer switch or interlocked breaker) so you can use grid instead.
That's an approach to determining what size inverter (and other components) you need.
You also have the old inverter size to give you an idea.
There are 3kW inverters, 5kW, larger. Consider one large enough to run all loads you would ever want at once.
There are cheap imports and well known well built products.
Your budget is a factor too - you can buy an inverter/charger, may also have PV input, from about $700 to $7000, some outside that range.
Especially because I have lead-acid I would prefer one which can blend PV & battery power with utility AC, so battery remains at float/fully charged so long as loads don't exceed programmed grid current limit.
Your lithium can take 5x or so the cycles of my battery. Inverter should have option to allow battery cycling to some DoD, so battery could cycle at night and recharge from PV during the day, not drawing from grid unless consumption exceed production over the entire day.
What size inverter would you suggest?
It costs you nothing to go ahead and run through the design steps now, so you know where you want to go ... a few calculations, power audit, and such will help you know what an "ideal" system is for your home and needs.
The design steps:
1. Go here, and enter in each appliance's values (watts, hours/day you want to run it, etc.):
https://unboundsolar.com/solar-information/offgrid-calculator
2. Go here, using numbers from above, and fiddle with various entries/components, and you'll see in real-time what your system component (inverter, mppt, panel) sizing is:
https://www.altestore.com/store/calculators/off_grid_calculator/
Once your initial calcs are done, you can see Will's videos & diagrams for example systems, under "DIY Solar ..." drop-down list at top of this forum. It's a journey, and lots of learning (some of which you've already done), but I think a fun one!
