fisherman
Good Morning,
I'm planning on adding solar to my cottage which is completely off grid. I'm trying to build it so I can scale out additional panels and batteries as needed. I really like the Victron line so I'm planning the below layout. I've done a power audit and will eventually need more batteries, but I'm hoping I'm on the right track. I'm looking for general feedback and also had a few questions.
1. What devices should I be grounding to earth?
2. If I'm using a Honda floating neutral generator to supplement the inverter/charger, is the bonded neutral/ground on the panel sufficient/correct?
3. Are there any additional fuses or components I should consider with this layout; aside from more batteries?
4. Is there a UL/CSA approved solar disconnect/combiner box? If not what are some good brands to consider? I'd need something that can handle 140v.
Thanks in advance.
Thanks in advance.
