robstrom
The Victron BP65 low voltage disconnect is installed.
The Samlex 1500 has a 3 position toggle (on/off/switch), as well as +/- to wire it.
In my case, can I wire the + from the load terminal of the LVD, and the - the inverter - post?
Will the low voltage disconnect switch the inverter off as well?
The inverter posts are the main points for positive/ negative cabling, the disconnect is downstream of it, as recommended by Samlex.
Thx
Thx
