The hole of the fuse terminal seems also quite big compared to the stud though.Thank you I have the smaller lug holes 1/4
I looked for 1/0 #10 lugs and couldn’t find any.
Also can I attach the fuses like this View attachment 190429
make your own out of crushed copper pipe
I have multiple fuses. I have a fuse on the battery, this one is for the fuse box - the fuse box says to use a fuse less than 125ampNo. Put the fuse in a holder.
And no, that big fuse needs to be where the conductor connects (or as close as possible) to the battery.
The fuse box is rated for 100amps and it said to use 1/0 cableAlso, in your original photo, when the terminal hole is too big you're losing contact area.
It's just catching the edges of the terminal.
That cable is also unnecessarily large for feeding that fuse panel.
Thank you I used your link to find #10 lugs for 6awgIf that is a Blue Sea ST blade fuse block, it is a not 1/4” stud. Specs make it look like a #10.
The block is rated for 100 amps total, 60 amps per circuit.ST Blade Fuse Block - 12 Circuits with Negative Bus and Cover - Blue Sea Systems
Compact ATO® / ATC® fuse block consolidates branch circuits and eliminates the tangle of in-line fuses for electronics and other appliances.www.bluesea.com
I fused mine for 50 amps and used 8 AWG 75 c wire with this stud
