Carlsbad_Solar
- Mar 23, 2021
- 5
I have a LVX6048 120V/240V from MPP Solar which is grid tied including a small solar array and a 280Ah LiFePO4 battery. I use the battery between 4-9PM when energy rates are their highest using a timed relay to disconnect from the grid. I have really run into a situation from day one when a few simultaneous kitchen appliances will overload one leg of the inverter while on battery. I have done my best to balance the circuits including moving appliances around, but I haven't had much luck. Obviously, I should have gone with a larger inverter, but I am stuck with this for now.
My question is whether I can use a solaredge autotransformer to help balance the load at the panel?
1.) I am not sure if the auto transformer can be connected while on grid power?
2.) Would I need to remove the neutral going from the inverter to the panel?
I was really hoping to just find a way to help balance the load on the inverter.
Thanks for the advice.
