Goboatingnow
- Jul 3, 2022
- 1,325
Certainly LTO is way safer and more capable then AGM , a mere review of the specs shows that.
Not sure what a Li-Ti cell is.
Can you define cold and why 600-900 CcA isn’t enough To start an outboard,mLi-Ti is short for lithium-titanate, just as LiFePO4 is short for lithium iron-phosphate. LFP and LTO are also acceptable abbreviations.
The battery you linked to is not suitable for cranking large outboards in cold conditions. It's probably fine in warmer temps, with engines that start easily, but it's not even close to providing the same CCA as a 100ah AGM battery. These newer options are great for many things, but cranking in cold conditions just isn't one of them. That's why you don't see many batteries being marketed for such.
I think Hedges pretty much covered it. What will work on an easy-starting engine at 75 degrees may not work on a cantankerous old 2-stroke, at 27 degrees. AGM's are superior when it comes to CCA, plus they're the correct chemistry for the current your alternator puts out.Can you define cold and why 600-900 CcA isn’t enough To start an outboard,m
Sure under 10 degrees without battery heaters is an Li drawback but as a starter LTO is far far superior in available cranking amps then AGM.I think Hedges pretty much covered it. What will work on an easy-starting engine at 75 degrees may not work on a cantankerous old 2-stroke, at 27 degrees. AGM's are superior when it comes to CCA, plus they're the correct chemistry for the current your alternator puts out.
Please don't misunderstand, because I really like every type of lithium-ion battery, but they're not the right answer for every application.
If that's true, ask yourself why no automobiles or diesel trucks or tractors (which require even more CCA) use LTO? LTO is "superior" , in some ways, but not when it comes to cold cranking amps. I don't know why you're having a hard time wrapping your head around that, but it's just the facts.Sure under 10 degrees without battery heaters is an Li drawback but as a starter LTO is far far superior in available cranking amps then AGM.
I am having a hard time because I’m right.If that's true, ask yourself why no automobiles or diesel trucks or tractors (which require even more CCA) use LTO? LTO is "superior" , in some ways, but not when it comes to cold cranking amps. I don't know why you're having a hard time wrapping your head around that, but it's just the facts.
Not sure why you feel the need to be dismissive when having a simple discussion.I am having a hard time because I’m right.
LTO is currently expensive that’s all , it will blow AGMs away. As AGM is a horrible lead acid battery ruined by its PSOC issues
Here some lto specs note thd huge cranking Amps from a 60 ah note the operating temp. Note the staggering cycle times. ( 300 for AGM )30,000 cycles at full current. The average outboard will be scrap iron before the battery fails.
This battery is capable of 10s of 900A no AGM can come anywhere near it
Note the -40 degree C operating range your puny outboard is likely frozen to a brick anyway. ( or the operator is dead )
Lead is dead baby , within a few years LTO will sweep AGM rubbish away, good riddance.
Wrap your head around thd AGM trouncing tech coming your way soon
Lto as a battery tech just depth charges AGM
Hindsight... 2020 but with a brown crap crust around it since you are looking out your butt!View attachment 107102
Painfully obvious in hindsight, but my lead acid battery overheated at some point, spewing out some water and sulfuric acid.
You can see the corrosion it caused to the lifepo4 terminals.
