Most list a max charge current. In the absence of information, 0.1C or 3.5A/battery is safe for all lead-acid.
AGM can typically go higher, but I would never go over 0.2C or 7A unless battery manufacturer said so.
In your case, ASSUMING YOU HAVE PROPERLY CONNECTED/BALANCED THE BANK, 5 * 3.5 = 17.5-35A.
It is difficult to properly balance 5 batteries in parallel. Even if you stay under the limits above, imbalance might force one battery to accept more current than the others.
