offgriddle
"FOREVER BEGINNING"
The Iceman Cometh
Ok this isn't my Bluetti and it was chosen by and purchased by a neighbor on the homestead. The neighbor has graciously offered to be the iceman, (he runs the freezer that supplies the ice for everyone's coolers).
He has four (4) 160 watt panels that each produce 8.78 Amps at 22.4 VOC currently connected in a series parallel arrangement producing 376 watts.
He also has two (2) 100 watt panels that each produce 5.93 Amps at 21.9 VOC
Considering the cumbersome maximum input limitations of the Bluetti's MPPT being 10 amps, 500 watts at 68 volts, and taking into consideration near and sub zero farenehit wintertime voltage increases, how would you all configure the panels?
IE:
Series Panel String One: 22..4 VOC + 22.4 VOC + 21.9 VOC = 66.7 VOC
Series Panel String Two: 22..4 VOC + 22.4 VOC + 21.9 VOC = 66.7 VOC
Parallel connect strings one and two and hope for the best?!
