Yes I do. I will try changing dod to 75% to hopefully avoid that issue.As soon as it hits the low setting (20%) it will give that error.
Do you have li-ion batteries with a bms with communication?
As soon as you hit _the_ limit it will give an error (i think of it as a warning)Yes I do. I will try changing dod to 75% to hopefully avoid that issue.
When it hits that error, it takes almost :30 to start charging again. I’m going to try to see if I can keep it just shy of that error.As soon as you hit _the_ limit it will give an error (i think of it as a warning)
ask your supplier for technical backupSo once the battery fully discharges, with no PV, the grid charges the battery. Once mine hits hits 99%, it just stays there. It doesn’t do the discharge cycle again.
I have asked GSL for support in the past, I get 100% more help on here. The reason the battery discharge frequency is an issue is since I have a 1kWh turbine and if the battery bank is full, it just dumps the energy and in turn I pay for the grid to charge the battery.ask your supplier for technical backup
I will try and reach out.ask your supplier for technical backup
From what I read here, GSL is making a great effort to provide support. My alibaba oem reseller of the megarevo (bluesun) isn't.I will try and reach out.
On SOLARMAN?From what I read here, GSL is making a great effort to provide support. My alibaba oem reseller of the megarevo (bluesun) isn't.
Once the questions get too technical and clearly to a problem, they stop communicating.
It is unnecessary that readings like battery charge/discharge kWh are still not readable (for me at least)
are those fields (Daily Purchased/Charged/Discharged) empty with your system as well?
yes?!On SOLARMAN?
And that is just filling in the right modbus value to read all those parameters. Megarevo is a joke (imo)Nope, just shows a blank.
Which app are you using? I have the SOLARMAN iPhone app.Those numbers don't add up and don't make sense
My desktop:
Vs my mobile app
The app seems to off with a big margin!
Problem is the lack of documentation with a lot of these new hybrid inverters. Both my Megarevo & my LuxPower lack any useful descriptions of the working modes.Do you know what would tell the inverter to discharge a full battery again? Example, the battery charges from the 20% SOC to what is displayed as 99% SOC on the inverter. The battery BMS shows its at 100% and constantly going into OV protect since its fully charged. Then randomly (or as far as I can tell) it will finally go into DC- DC discharge mode and power my loads with the battery down to 20% SOC again. I am trying to figure out if its waiting a certain amount of time when the battery is full before cycling again or for some other signal?
Yes, I have been restarting it after the changes (which is a PITA when having the critical loads panel connected)Have you power cycled the unit after changing the settings?
With the same settings we should not have different behavior.
Power cycle is switching off PV, batteries & AC
Warning: your daily readings will be reset
