MisterSandals
Participation Medalist
I guess I was assuming you were charging the whole battery together. If one of the 4 packs (4S?) is getting warm, I would suspect it’s voltage may be higher than the rest other 3 packs of 8 cells.
And to keep from overcharging the cells and packs, you need to monitor their voltages.
If you were charging at the pack level, at around 3.4V with constant voltage that wouldn’t be an issue if it stopped charging at the target voltage.
You did not really explain how you are charging.
