The_Nerdy_Traveler
- Jul 30, 2022
- 1
I'm out in the field, I hook everything up - battery to MPPT, PV to MPPT, power up via circuit breakers, connect 2000W inverter(most likely modified), Sola Constant Voltage Transformer, then the microwave (700W 1100W/120VAC).
First time using the microwave and CVT.
Microwave powers on, but will not power up to heat up food. I take out the CVT, and it the microwave heats up, albeit louder noise. This really should have been my first clue, but I thought that I had a defective CVT since it is vintage.
Tried to make some microwaved popcorn, nope. Booooom! Out comes the smoke from the back of the inverter. Power is still on, just no more heating up. Immediately turn off inverter. Open it up and the middle capacitor has blown, and it looks the one next it was going that way as well.
Inverter is still producing AC, so I will replace all 3 capacitors.
Any ideas here as to what why the capacitor blew?
From what I read on-line and here: 2000w inverter should have handled the power ( 700*2=1400). Use a long extension cord next time to keep surge down. Inverter probably cant handle the microwave to begin with - too cheap.
