Hi all,
I built a 280AH battery using a 120amp Overkill BMS. I've got a 2200 watt pure sine inverter and I tried to run my rv microwave and it shut down the bms. Looking at the specs on the microwave, it takes a 1500 watt as input, 1000 watt as output. So that makes sense... 1500w / 12v = 125 amps. I guess the bms should shutdown. So I then tried to run the microwave on low power thinking that that would reduce the input amperage. Nope, still shutdown the bms. Strange, unless the input stays the full 1500 watt amount regardless of the output.
So, I am now considering swapping out to a smaller 1000 watt microwave in the hopes that it wouldn't shutdown the bms. 1000w / 12v = 84 amps. Do you think that would work?
Thanks so much!
Thanks so much!
