dhruv_pareek
Hello, I am trying to use a microcontroller (specifically an Espressif ESP32 with an RS485 MAX module) to communicate over MODBus to my JBD BMS (model name: JBD-AP21S001) but I am having issues getting this to work.
I understand that there is an RS485 Communication Module that JBD sells with the BMS (https://www.aliexpress.com/i/3256804168676247.html?gatewayAdapt=4itemAdapt#nav-specification). Is MODBus communication to the BMS only possible by purchasing this module? Or is this module only necessary if you desire to communicate with the BMS through your laptop?
The RS485 port on the JBD BMS only has two pins built in for A and B, just connecting my RS485 MAX module to the two A and B pins of the RS485 port of the BMS does not work properly. I also tried to solder on wires to what looks like a ground and BAT+ label of the RS485 port, then connect these wires to the GND and 5V of the ESP32, however this does not work properly either.
So do I need the RS485 Communication Module that JBD sells with the BMS (https://www.aliexpress.com/i/3256804168676247.html?gatewayAdapt=4itemAdapt#nav-specification) to communicate over MODBus from my ESP32 with an RS485 Max module?
