drunkenmugsy
Here is the plan in a nutshell:
Want a solar kiln to dry wood. Thinking I can use a 20' shipping container to make a modified solar/dehumidification kiln. Using PV to power a 600W AC dehumidifier for 4-6 hours per day. Using PV to run a dc pump on a closed loop solar hot water heater to heat the container, 80W DC 4-6 hours per day. Using PV to power inner air circulation fans 100W AC 4-6 hours per day. PV to run air exchange fans 100W AC 1-6 hours per day. PV to run a monitoring system >100 DC watts 24hrs.
Total watts at peak would be 1000W+- for 4-6 hours per day. Longer would be great. Less expensive would be priority after 4-6 hour run time is reached.
Budget is under 5k$ including 2k$ for container. More is possible I just need to justify it to myself.
I have been using a solar kiln that a friend has. It works great in the summer. Not so much in the winter. What I am looking for is a system that will work year round with reasonable cycle times.
Some input on how to weatherize components would be useful. Inside the container will be a 'water condensing environment' obviously. The only things that will be in the container are the dehumidifier, fans and sensor probes. Everything else will be exterior attached in a mini solar shed. Something I can mount on the container itself is what I picture. Solar panels as well as the water heater loop mounted to the roof. Grid power is available but I would have to run it overhead DIY. Not ideal but possible. Off grid would be preferred.
Using a standard dehumidifier kiln pack for several thousand dollars and 220v power is not an option. The solar kiln works great. I just want to turbo charge it if possible. Worst case is I have a solar thermal kiln that is slow in the winter.
What other clarifications or info am I forgetting?
