patfinegan
- Jul 31, 2022
- 14
Confessions of a Solar Newbie
Several years ago, I installed a cable modem, router, and WiFi security cameras on a remote, vacant estate I manage. I installed the network of security devices after several break-ins, occasional vandalism, and a secretive, six-month squatter.
The intruders caught wind and, rising to the challenge, tampered with the USB charging devices (yanked cords), wiped SD cards (covered their tracks), and otherwise trespassed and squatted as usual. So, I replaced many of the cameras with hardwired Ethernet ones, mounted others at great height, changed all my locks, added deadbolts everywhere, and pondered how to defend against the easiest way to defeat my security system – a power failure. I padlocked the fuse box, hid the extra fuses, and installed a Jackery Explorer 1000 in the attic with three 100W Renogy solar panels on the roof. I ran grid power (Con Edison) and the Jackery’s inverter into an automatic transfer switch (Con Edison as primary, Jackery as backup), and ran my cable modem, router and Ethernet cameras off the ATS. Easy peasy.
But then I questioned why I was wasting so much solar energy. If I could just monitor the wattage remaining in the Jackery, I could reverse the ATS, making the Jackery unit primary and grid power secondary (a backup). The problems were immediate. When the Jackery’s battery depleted, it shut off inverter output , the ATS switched to Con Edison grid power as intended, but, here's the problem, the Jackery did not turn inverter output back on when the battery recharged. It required a manual push of the Output button, something that was impractical for a remote, vacant property.
So, I attached a WiFi-enabled smart plug to the inverter output, so I could turn off its output, and thus instruct the ATS to switch to Con Edison grid power, when I felt the battery needed to recharge. Unfortunately, there was no direct way to monitor the Jackery’s battery’s state of charge, because the LCD display cannot be monitored by app (none, at least, that this solar newbie is aware of) or even a security camera, because the LCD display goes blank unless someone manually pushes the Display button. So, I programmed the smart plug as a timer – on at 7 am, off at 11 am, leaving the rest of the day for the battery to recharge. That worked for just three days. Hyperactive security footage on one of the days blew through the Jackery’s 1000 watts and the inverter output shut down. There was no way to restart it without a manual push of the Output button, but I live 2 hours and a car rental away. Frustrating.
My next gambit. I plugged a WiFi-enabled smart plug into a regular power outlet (Con Edison), plugged the Jackery’s AC/DC transformer charger into that smart plug, and plugged the transformer charger into the JE 1000’s unused DCM 8 mm input. I timed the smart plug to enable grid-based recharging of the JE 1000 from 6pm to 7am, thus ensuring that the JE 1000 begins every morning with a full charge, regardless of how much juice the solar panels produced the previous day. Hopefully, this configuration will utilize all available energy from the three Renogy panels but avoid prompting the JE inverter output to turn itself off unexpectedly. As for the cable modem and router, I bought an uninterruptible power supply. That will function long enough to instruct the smart plug on the JE inverter to switch on, powering my PoE (power of Ethernet) security devices. If the unit still conks out, I will shrink the inverter’s output time frame from 5 to 4.5 hours, then 4.0, etc. to whatever time frame the JE can reliably handle.
My questions for those with more solar experience. (1) is this approach nuts, (2) is there a direct way to monitor the JE 1000’s battery state remotely, (3) is there a pertinent app I don’t know about, and (4) has anyone tried to accomplish something similar and, if so, what insights can you share?
Thank you in advance for your patience and kind assistance.
