Monitoring Bluetti Systems
@MrGPS Hmmmmmm. That warning that it's using Python 2.7 for pip seems like a problem. I went ahead and installed Python 3.7 just to test this and it works perfectly to install without any dependency issues. You might want to try python3 -m pip install bluetti_mqtt to force it to use Python 3.7 instead of Python 2.7 on your system. It's also possible that pip3 install bluetti_mqtt would work too - you might not have a pip3 command though.
Can you tell me how i must do this? Or can you send me an example string for the DC-input query?
@Tinkerpete Yeah, the string you need to send for the DC Input Power is "\x01\x03\x00\x24\x00\x01\xc4\x01". I did a detailed breakdown of how this is all built earlier in the thread so I'm not sure if you read that and there was something I said that was still unclear or you just missed that.
For the last two bytes you're going to need to find a C++ library that can do MODBUS CRC16 if you you actually want to construct arbitrary commands yourself in C++, but another option would be to just use the Python code for now for that. It sounds like you managed to install the Python code, and so you should be able to use that like this:
Code:
$ python
Python 3.7.3 (default, May 22 2022, 10:21:14)
[GCC 10.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from bluetti_mqtt.core import QueryRangeCommand
>>> bytes(QueryRangeCommand(0x00, 0x24, 1))
b'\x01\x03\x00$\x00\x01\xc4\x01'
Edit: Feel free to DM me or send me an email at the address on my Github profile if you have more questions. I might not respond immediately, but I'll definitely get back to you as soon as I can. I'm happy to help anyone who wants to work on this.
@chromedshark: Many thanks for your help!
In the moment this is my biggest problem. I know this is hex code. I think i can read this as: 0103-0024-0001-c401. But I did not understand, where i must insert this in a notify characteristic string like this: "0000ff01-0000-1000-8000-00805f9b34fb"?
I have see this, but not analyzed! :-) I will do it.
For MODBUS i found that:
I will test it later.
Yes, i can run your python code on my PC. But it did not find the bluetti.
b'\x01\x03\x00$\x00\x01\xc4\x01'[/CODE]
This works!
Are you not comfortable with us continuing this in this thread?
@chromedshark:
I have test this function:
Code:
unsigned int CRC16_2(unsigned char *buf, int len) {
  unsigned int crc = 0xFFFF;
  for (int pos = 0; pos < len; pos++)  {
    crc ^= (unsigned int)buf[pos];    // XOR byte into least sig. byte of crc
    for (int i = 8; i != 0; i--) {    // Loop over each bit
      if ((crc & 0x0001) != 0) {      // If the LSB is set
        crc >>= 1;                    // Shift right and XOR 0xA001
        crc ^= 0xA001;
      else                            // Else LSB is not set
        crc >>= 1;                    // Just shift right
  return crc;
unsigned char arr[6] = {'\x01', '\x03', '\x00', '\x0a', '\x00', '\x37'};
Serial.println (CRC16_2(arr , 6));
and get: 7716 = Hex 1E24 !
Is this correct, because the bytes are changed in order?
If so, i can it made right with:
Code:
unsigned short rightRotate(unsigned short x, short d) {
  return (x >> d) | (x << (SHORT_SIZE - d));
Code:
Write Command - FF02 - Value: 0103 000A 0037 241E
  1. The final two bytes, 0x241E, are the checksum. I can calculate this checksum with the code I already have, which is a good sign that I should be able to use it for any devices they have. When I add "01" to the beginning and checksum everything except the last two bytes, I also get 0x241E (which suggests that I'm probably running the checksum on the wrong stuff if changing the payload does not change the resulting checksum).
It's not a UUID - it's just a string of raw bytes. Once you have the write characteristic (the BLERemoteCharacteristic*) you'll notice it has a writeValue method for either a string or raw uint8_t array. You'll just call it with any command string. The default for setting response to false here works fine. If you did it correctly, then shortly afterwards you should receive a notification on the notify characteristic with a response payload (which you can then decode).
Yes, that's the same value I get from the Python function I'm using. Most of the binary protocol seems to use network byte order (big-endian), but the CRC appears to be little-endian, so when you use it to build your string the byte order is reversed.
Code:
$ python
>>> import struct
>>> from bluetti_mqtt.core.utils import modbus_crc
>>> modbus_crc(b'\x01\x03\x00\x0a\x00\x37')
7716
>>> struct.pack('<H', 7716).hex()
'241e'
If it's working for you then that's all I'm looking for.
Thanks for the Tip, with the force function is working now by using the !!! "python3 -m pip install bluetti_mqtt"
You have really done agreat work. Thankyou very much.
FYI, i got the following warning:
"The scripts bluetti-logger and bluetti-mqtt are installed in '/home/pi/.local/bin' which is not on PATH."
By changing your command to "python3 /home/pi/.local/bin/bluetti-mqtt" scan, broker and debug are working.
There is only a minor problem left, exactly every 30 minutes I get 0W on "DC Input"in Home Assistant.
Does anybody else with an EP500Pro have the same problem ?
UPDATE: I watched the LCD display on the EP500PRO and it also shows that every 30 minutes both PV Inputs go down to 0 for a few seconds.
I guess it does some recalibration. I'll ask the Bluetti Support.
Anyway, the Python Script works perfect. Once more Thank you very much.
@slowdiver:
How do you log data via iobroker? I've connected my Raspberry PI with iobroker and MQTT-Broker. But there are only states from the beginning of the connection but no actual data.
@slowdiver:
@ApolloSK
Hi ApolloSK,
sorry but I moved the AC300 from my working room now to the final destination (basement). There is currently now Raspi there, so I can't test.
But if it was active, I saw changing values all the time. Values were only NOT changing if it was the same VALUE as before. I'm running only bluetti_mqtt on the Raspi. iobroker is running on a Linux box. There's MQTT Broker/Client running. Please check also If bluetti_mqtt is still running (check the logfiles), because serveral times the process was up, but no news in the logfile. I restartet the process and the updates in iobroker was visible again.
Fantastic job ! I operate a Bluetti AC200MAX and i monitor the device with a Raspberry Pi 3 and this software. I run bluetti-mqtt as a service in systemd with the following data:
[Unit]
Description=Bluetti MQTT
After=network.target
StartLimitIntervalSec=0
[Service]
Type=simple
Restart=always
RestartSec=30
TimeoutStopSec=15
User=pi
ExecStart=/usr/local/bin/bluetti-mqtt --broker 192.168.10.152 --username sh --password 12345 --interval 10 00:15:83:8A:FF:D3
[Install]
WantedBy=multi-user.target
This works fine for a certain time (a few hours up to a few days). Suddently no data are sent to the mqtt broker anymore. I have to restart the service and the data come immediately again.
How can i detect the reason for stopping the transmission of data ? Are there log files generated ?
It's possible this is the same reason as this other report. When running services with systemd, logs are automatically sent to syslog, and should be readable by running journalctl -u name-of-the-service.target. You can use the -n 100 flag to specify the number of lines to print out, or the -f flag to print out each log line as it's generated by the service.
@ApolloSK When you run bluetti-mqtt for the first time it "permanently" adds those homeassistant keys, so any time a client connects to the MQTT broker it'll receive that config data automatically. If you're not seeing anything other than those keys then the script is probably not running for some reason. I would check the logs to see if it crashed or something.
I started the service on the 12. Sept at 22:10 and i see these data in the log:
Sep 12 22:10:27 garage systemd[1]: Started Bluetti MQTT.
Sep 12 22:10:34 garage bluetti-mqtt[851]: INFO:root:Starting to poll clients...
Sep 12 22:10:34 garage bluetti-mqtt[851]: INFO:root:Connecting to MQTT broker...
Sep 12 22:10:34 garage bluetti-mqtt[851]: INFO:root:Connecting to clients: ['00:15:83:8A:FF:D3']
Sep 12 22:10:34 garage bluetti-mqtt[851]: INFO:root:Connected to MQTT broker
Sep 12 22:10:34 garage bluetti-mqtt[851]: INFO:root:Sent discovery message of AC200M-2211001616047 to Home Assistant
There are no further data till now, but the service does not send data. The service is still running:
pi@garage:~ $ sudo systemctl status bluetti-mqtt
● bluetti-mqtt.service - Bluetti MQTT
Loaded: loaded (/etc/systemd/system/bluetti-mqtt.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2022-09-12 22:10:27 CEST; 2 days ago
Main PID: 851 (bluetti-mqtt)
Tasks: 2 (limit: 779)
CPU: 16min 11.366s
CGroup: /system.slice/bluetti-mqtt.service
└─851 /usr/bin/python3 /usr/local/bin/bluetti-mqtt --broker 192.168.10.152 --username sh --password 12345 --inte>
The process is visible in "ps -ef" too.
The data are back, when i restart the service.
Hey guys, first Thank you very much for your efforts and for @chromedshark for all his help answering my emails and getting me this far!
I have everything setup and working to Home Assistant... but I do have a question on how to parse a topic that has json payload.
I'm looking at topic "bluetti/state/AC300-##########/pack_details1" to run an automation in Home Assistant, but I need to check the value of the key "percent" in the json payload and use it to execute action if the value drops below a specific value.
Hey guys. So I did figure out how to parse the json in the pack_details1 topic by editing the mqtt.yaml file and adding a sensor.
One thing that I notice is that when I added my second AC300 the "AC Output" entity bounces back and forth from enabled to disabled. I'm thinking this is because my system is in Split-Phase mode and even the Bluetti app only shows my Master unit's AC Output enabled. The slave unit shows it always off on the app.
Has anyone else seen this?
I added a periodical restart in systemd with the line "RuntimeMaxSec=3600s":
[Unit]
[Service]
Type=simple
Restart=always
RuntimeMaxSec=3600s
RestartSec=30
TimeoutStopSec=15
User=pi
ExecStart=/usr/local/bin/bluetti-mqtt --broker 192.168.10.152 --username sh --p>
[Install]
Now i can monitor my device continuously.
@twister36 I only have a single AC300, but I suspect this is because one of the two places that value is stored should be ignored in this case. The question is which. If you use the bluetti-logger command to collect logs from both your devices (just run it for ~5 minutes against each device) and send them to me I can probably fix this.
@chromedshark: My program fetches one value at a time. Do you do the same? Or is there a way to fetch all values at once?
@Tinkerpete Short answer is that there is a way to fetch multiple values at once and I'm doing that in bluetti-mqtt.
The longer answer is that can you use a query command (the 0x03 command) with a size greater than 1. The command 010300240001C401 will return a single field, the DC Input Power (stored at 0x00, 0x24). The command 01030024000E8405 will return 14 fields (0x0E) from 0x24 to 0x31 inclusive, covering all the data that the mobile app displays on the main page.
As far as I can tell, the Bluetti only supports Bluetooth LE communication in fixed size packets. Once you cut out all the overhead, you're left with 20 bytes of data that can be stored in each notify packet - the amount of data that the Bluetti can send back in a single packet in response to a query. The Bluetti messaging protocol has 5 bytes of overhead (3 for the header and 2 for the CRC), so that leaves 15 bytes. If the size of your range query exceeds 15 bytes, then the response is split across multiple packets and you must reconstruct the full response by concatenating them together. This is what I'm doing in bluetti-mqtt, but it means I had to handle a bunch of other complications (timeouts, packet loss, packet corruption, etc.). Also, as the number of packets that need to be combined goes up, the odds of the entire response being corrupted goes up, so I've found that the sweet spot maximum is ~8 packets. If you don't want to deal with this complexity then you certainly achieve what you want by limiting yourself to requests for at most 7 fields in a single request (each field offset is a 2 byte value) and just making more requests.
The ideal architecture for this is two "threads": one for making requests and one for processing the response. You cannot make a new request until the response to the previous request has finished (or some timeout is reached), so the request thread is blocked waiting on the response processing thread. The response processing thread handles concatenating the pieces together, detecting when it has received all the data it's supposed to based on what the query was, verifying the checksum, and then notifying the request thread that the request is completed. This architecture then simplifies how you interact with the device in the rest of your code to making requests and either receiving a response or receiving some error.
@chromedshark: Thank you for the detailed answer! The query of the individual values works very well for me. I was just wondering if this could put any strain on the Bluetti if, as I do in my programme, 12 values are queried every 5 seconds? In this case I would try to program it as you have described. But first of all, there seems to be no compelling reason for it.
Really appreciate getting all this started @chromedshark and others!
For anyone looking for a super simple way to integrate into HA OS (Home Assistant Operating System), here's the cleanest, lowest code route I've found:
Find your device ID: I did this by getting into the HA OS host, then Docker instance, then manually installing bluetti_mqtt (pip install bluetti_mqtt) and running the --scan command (there's likely an easier way to do this).
Setup MQTT (if you haven't yet): Follow directions here - https://www.home-assistant.io/docs/mqtt/broker/ (including user/password combo)
Create script/shell_command integration: I created a new directory in /config/ called "shell" and placed a new script called install_start_bluetti_mqtt.sh in it. Inside that script (replace USERNAME, PASSWORD, DEVICE_ID with yours):
#!/bin/bash pip install bluetti_mqtt nohup bash -c "bluetti-mqtt --broker 127.0.0.1 --username USERNAME --password PASSWORD DEVICE_ID &"
Once that's in there, add this to the root of your configuration.yaml:
shell_command: install_start_bluetti: bash /config/shell/install_start_bluetti_mqtt.sh
Setup automation: Super simple automation that trigger's on HA start (can create with the GUI in Settings>Automations>Create Automation):
Note: the "id" value here has no connection to the DEVICE_ID, it's auto-generated by HA when creating a new automation
- id: '1665937079543' alias: Install and start bluetti-mqtt on HA start description: '' trigger: - platform: homeassistant event: start condition: [] action: - service: shell_command.install_start_bluetti data: {} mode: single
Have this up and running for my WIP AC300+2xB300+2xPV350 build - running HA OS 9 on a Raspberry Pi 3. Obviously a temp solution, but working well for now! Going to dig into HA OS 9+ BT support and see if I can help further a native HA integration.
Thanks for the Tip with the Bluetti_MQTT integration, i’ll try that when i am back from vacation.
I have an EP500Pro with 2 PV Strings attached and currently run the Bluetti_MQTT part on an Raspberry PI.
The native integration via HAOS inlc. native Bluetooth integration would be really great.
Setup automation: Super simple automation that trigger's on HA start:
Hi thank you for the manual the only what by me make troubles is the Setup Automation show here 1666499225900.png have you a idea what is wrong ?
