42OhmsPA
What's in a title?
I already have the PNY CS900 I linked above, I'll check out the crucial.I would recommend going with linux. The proxmox downloads will have an image you can get that will install it all for you onto the machine then all of the virtual machines you add will feel windows like thru the web interface. Windows has too many things running the background to work all that well.
Your kind of defeating the whole idea of the minipc vs the pi route with windows running on it
Remember the virtual machines are all your interested in with a setup like this. Also reading that webpage you linked for the minipc you have showed that the seller was using very cheap ssd drives and that they were slowing the machines down badly. Make sure the ssd drive is decent to keep from causing a bottleneck performance wise. Good ssd's are very cheap now. I highly recommend the crucial mx series ssd drives since they have a capacitor in them to keep data from getting corrupted if the power fails that's running the pc.
I agree windows is a terrible data hog.
So I install Proxmox and HA on the SSD, configure and it's up and running?
