kaseycoleman93
I am hoping to narrow down what engine to use on my generator build. I'm planning on using a ECP28-S/4(15kw 240v 60hz) or possibly a ECP28-M/4(17kw) depending on the feedback I receive here. Here are my 2 questions:
Which engine would you choose based on prior experiences? Most important for me is fuel economy. Load will generally be around 6-7kw. Perkins, kubota, isuzu, deutz, mitsubishi? I'm hoping to be close to .5 gph. The goal is to have power as cheaply as possible when it's all said and done.
Second question, is using a generator end that has a larger output capacity going to use more fuel spin, at all loads? A 15kw will be more than enough for my needs, now and future. The 17kw is only slightly more cost.
Thanks for any and all input.
