Checkthisout
Emperor Of Solar
- Nov 14, 2021
- 5,439
So some of these open frame Hondas have auto choke. Thus makes them super easy to turn into auto start. This one also has a 6 pin connector designed to hook into a WIRED remote control panel which also makes it easier.
Modifications:
1) Interrupt starter cranking once voltage is present on 12V charging outlet. This is done with a relay with n/c contacts that open once 12V is applied.
2) Install relay that applies battery power to 12V outlet while cranking to power/prime auxiliary fuel pump. Once 12V is output by charging outlet coil, the relay receives power and switches over normal 12V charging coil. This powers the aux fuel pump. The fuel pump stops running if engine stops running.
3) Only 4 pins on 6 pin connector are used. Added 2 more pins to monitor battery voltage and starter on signal. This allows for overcrank to be detected.
The controller resides in the plastic box and harness connects to 6 pin connector on generator. Might be hard to see the thermistor at the generator air inlet but it monitors temperature of the air getting pulled into the Gen head.
Just using 30 amps for now. You can see fuel pump power harness hooked to battery charging outlet posts. So as said above, those posts recieve battery power while cranking then normal battery charging coil power once running. Power then runs into box where there is a voltage stabilizer since the 12 charging port receives unregulated power.
Auxiliary pump. Just pumps right into carb. Took fuel line off tank valve and just connect with 1/4 to 1/8 barbed adapter. Easy peasy. Pulls through a fuel water separator from a 120 gallon tank.
All lives in this hut. A recycled modified 66KVA generator enclosure.
Modifications:
