The wood backboard is not the problem here, it's the use of an AC ground bus bar for DC power connections. Depending on his batteries and load he could easily push 200 amps. Most inverter specs do call for non-flammable mounting surface for their unit, which is not needed for daily operating temps, however if there is an electrical failure you have another layer of safety.Admittedly I only read half the answers.
When we build "backboards" for our telephone and signaling circuits we use fire rated plywood painted with fire retardant paint. The we mount all of our busbars, blocks, etc. onto that backboard.
Funny thing is we have to leave the square patch that shows the fire rating of the board unpainted for the inspector to see it.
Since all of our "stuff" is DC voltage. Mostly 48VDC I would think that is the appropriate thing for all DC voltages. At least 48VDC and below.
Understood. Okay. Yes. Never (at least that is what I was schooled) use Ground bars for anything but ground bars. LOL.
Busbars for voltage usually have some "dork" proofing. Like covers, washers, etc.
The Hardyboard is really the best way to go!I use cement board to mount my equipment , Hardyboard siding
Of course, it's in the shed. After the pieces were cut then sealed with Kilz primer we were good to go, works excellent. I will also use the 1/4 Hardie board for the bottom, back and top of my battery bank.Not for internal use. The silica dust it emits is a huge HSF issue as if breathed in you will have long term repository issues. For outdoor use it's fine as wind/etc blows any dusting away. For cutting the use of a proper respirator is important.
Hmm , try that PVC. / Plastic / composite wood . It worked good for me , using bus / ground bars . This is my interior power / mechanical closet.I'm building a 24V lead acid battery bank and I was going to mount both positive and negative bus bars onto the wood structure that will hold the batteries in place.
I saw a thread recently where a user shared a near disaster experience where wood planks were in contact with LiFePO4 cells. My personal and non-professional point of view is that wood should be non conductive for 12V~24V.
Should I under no circumstances screw the bus bars to the wood? You think I'm a mad man?
What would you do in my place?
I already have the wood structure ready and the 125A (I think they're some kind of brass alloy) bus bars. They are advertised as (AC) ground bus bars.
Thanks for your thoughts in advance!
Fahrenheit 451I'm building a 24V lead acid battery bank and I was going to mount both positive and negative bus bars onto the wood structure that will hold the batteries in place.
Hardie board is not intended for structural uses. It will not support heavy objects where there is vibration — the screws will fail. I suppose it could be used as an intermediate, non-flammable layer with plywood below, but it wouldn’t be the best for that purpose because it does transmit significant heat.The Hardyboard is really the best way to go!
