Movable Solar panel cart
JJJJ
Aspiring apprentice
Last weekend I was lugging around a solar panel, trying to see what locations would provide good solar input. After lifting it for the xxx th time, I decided to make a cart, or dolly to move it around. It is not finished but I thought I would share progress as I go.
The panel is slightly counterbalanced making the bottom half slightly heavier. This enables a minimal amount of effort to swivel it up or down.
Currently I am feeding the input through a Morningstar charge controller I had laying around. It measures amps providing the AGM battery I am getting if it is not nearly charged:
I have eye hooks on the back and on the sides. The sides will enable to stake this down should I encounter any wind. The ones in the back allow a taunt line such as used with tents. I can adjust the tension and hold the panel at a multitude of tilt angles.
I went out and found an inexpensive line of sight monitor which enables me to set the orientation to south and tilt to best match the sun. Granted I could just use a pop can but this was more fun.
After trudging around the yard with this, I decided I need a better way of steering this. The 4 Harbor Freight wheels keep it stable, but lifting up the one end to steer it takes away the fun of moving it. I am exploring putting a trailer hitch jack with a pivot wheel. This will enable me to lift the front slightly and steer it more easily. When I get it to the desired spot, I will crank it down, back onto 4 wheels. I saw Harbor Freight carries these as well so may need to make another drive soon.
I currently have a fuse before the battery. I have purchased a small outdoor breaker box and will be putting my solar panel input through that and on to the battery.
As with many projects, the to-do list never ends. There are a few things I would like to address:
1. Provide it with a good coat of solid stain.
2. Clean up the taunt lines.
3. Dress up the solar lines to the breaker box and on the the battery. They are a jumble and take away from the neatness I would like to see.
4. Improve steering ability. So far the hitch idea is leading the way in the list of prospects.
And other tasks as I get through the list. Naturally this list will probably grow as I go along.
Installed an in line breaker and cleaned up some wiring.
As an added bonus it fits in my shed. That was a happy coincidence.
Nicely done ! Next step is to motorize it ?.
Do you have a link to that line of sight thingy ?
Thnx. I just bought a new grill and want to use it where there's no power and was just starting to search around for ideas.
Well this spring looking to update this build to interface with another project:
Currently in the design phase for Revision 2. This model will be lower to the ground and will be on wheels as well. Because the pivot point will be on the side it is anticipated that it will have a lower center of gravity. The new design will have a limited number of angles available and use a side support to set the angle. Will post in another thread as progress is made.
i have some things on 8 inch pneumatic caster wheels that I bought at the local ace hardware. Probably sold by a lot of places.
Not cheap, but very convenient for going over softer ground.
I built a rolling cart from a 4 x 8 sheet of plywood and 2x4s around the edges for strength. Holds a lot of stuff.
Edit - this is just an example of what they are - I bought them years ago and don't know the exact model of wheel.
Would you want 2 swivel casters & 2 non swivel or do you think all 4 swivel castors would be better?
Just thinking 2 non swivel might help in a windy situation, even though you would have the casters locked..
For this version, having two swivel wheels on one end could be a good consideration. Reason I went with the single wheel hitch wheel. My updated model has two front wheels only and the ability to lift like a wheelbarrow and steer from the other end.
Thanks. I'm trying to decide how to proceed with my own cart.
The wheelbarrow aspect might be more stable, especially if it gets windy.
I appreciate your input..
I was in the Big City today, dropped into a Princess Auto which is similar to Harbour Freight in the US. I was really amazed at the various wheels, casters all the way up to full on trailer axles & wheels. I immediately started thinking of your cart JJJJ and pondering.... Hmmm I have an HF 3000W inverter and a 105AH LFP pack and.... Geez Louise ! I escaped with a Magnifying Light, some wire & a framing square, phewwwwww
I picked up a welding cart when it was on sale at HF. It holds my 24V battery, charge controller and inverter.
