I'm in a similar situation.
I have a 3 ton unit that runs our large bedroom suite. I bought a 1 ton window unit (my wife isn't too have with the look), and use it to supplement the 3 ton unit. The window unit is PV only and I run it all night. It helps the 3 ton central air quite a bit.
But I'm getting to the point of maybe taking the 3 ton unit off the grid and just powering it from PV. My problem is my PV daily input. I'm in the 33-40 kw per day range. The 3 ton unit runs about 22-25 by itself with no window unit 'help'.
This fall (after the summer heat), I'm going to replace my 400w panels with 450w panels....and add 3 more (7 vs 10). I think I'll have the daily PV input I need for next summer and will most likely pull the window unit for good. It became an experiment really.
And by the way, my 18kpv inverter easily starts and runs the 3 ton unit. Although I haven't tested that when the sun is down. But I have a pretty serious battery bank, so it should be good.
PS - I don't have any, but the Mini Splits look awesome.
