skinnyportagee
- Oct 15, 2022
- 3
Hi, I am looking to make my first system. My goals with this project are:
1. Learn more about solar
2. Power a few smaller loads (full-time), such as my computer, phone charger, and other small devices at my desk.
3. Act as a backup system if the power goes out for an extended time. For this I would just manually plug in our full-size fridge, charge phones, recharge some flashlights. Not a whole house backup, more like a portable power station.
I bought a Kill-a-watt and my loads seem reasonable for this plan.
I am looking at the MPP 1012LV-MS. My current plan for placement is having the unit in the garage and around 600W ground mount solar array on the side of the house where it would get full, southern facing sun all day. It would require my PV wires be about 40-50 feet. For the short-term I will probably just use an extension cord for the AC output but I'm thinking about wiring a small sub panel with two 15A breakers and dropping two outlets inside the house that I could run some permanent devices on (like my computer).
I had a few questions about these MPP units that I wanted to confirm.
1. If I am going to connect the AC input to an outlet on my main house system, will that sufficiently ground my system? The more I read about this on other threads the more confused I get.
2. On the note of grounding, do I need to do any grounding with my solar panels too?
3. Do I need a fuse between the MPP and the battery on the positive connection? I've seen some videos with and without one. I plan on using a Power Queen 12V 300Ah lifepo4 battery. If I need a fuse, what is the correct way to calculate the size I would need... is it based on a charge controller spec or a battery spec?
4. For my panels, I may look and see if I can find two used 300+W panels, but if not, I can use three 200W Rich Solar panels that I can get off Amazon. The Voc is 24.3. For three that's 73V and the MPP has a max of 102V. That should leave enough headroom, right?
5. The MPP 1012 says it can be over paneled with 800W. To do that I'd need to run four panels in 2s2p. When introducing a parallel connection, do I just use the Y adapters or do I need to use a joiner junction box with fuses?
6. Would 10AWG PV wire be the right gauge?
7. Is there anything I am missing or should be doing differently?
8. I also looked at the MPP 2024 Hybrid but it has a higher idle consumption and might be too big for my needs. Is it better to upsize or would it be ideal to stick with a 12V 1012?
Thanks in advance!
Thanks in advance!
