MPP LV6548 or Growatt SPF5000ES? I'm building a new off grid house. The only 240 volt loads are a 3 hp submersible
pump and a 3 ton Carrier Infinity variable speed heat pump. Propane will heat the water and
cook the food. I have 6 new EG4-LL 48V batteries. I'm undecided on inverters. I'm considering 2 LV6548 inverters and 32 455W panels
with 4S2P per PV input which was covered in a previous thread. Or, 2 Growatt SPF5000ES inverters and yet to be determined panels.
I'm new to solar. The indecision comes from two facts. The first is the LV6548 does not communicate with the EG4-LL BMS. The second is the Growatt has to deal with a transformer which would suggest the selection of a 5kW 5000ES and transformer kit from SS. I would appreciate any suggestions and reasons for selecting one over the other.
Or, is there another inverter that would be a better choice? Thanks.
