Mpp solar 1012lv-ms question
scmoore
the manual calls for 16 gauge wires from the generator to the inverter. Is there a reason why I can't use 12 gauge wires? I don't even know where to find 16 gauge wires, maybe cut a cord off a box fan.
Don't know if my unit will charge the batteries, have not seen the sun since i hooked it up so today I hooked the generator up to it and it just keep blowing the GFI. It has a button on the bottom that appears to be a breaker that is just loose. Seems to me to be a dead short in the unit somewhere.
Sun came out today and the unit is charging. Shows no volts on the indicator coming in but have 35 volts at the line and the battery voltage is coming up. What should the voltage settings be for charging lithium battery default settings are 14.1 bulk charging, 13.5 float and 10.5 low dc cut-off
