Mpp Solar LV2424 handle 300ah battery bank?
Brayden
Can the LV2424 handle a 300ah battery bank? I have 4 Lion Safari 1300 batteries connected in series/parallel for a 24v system and want to make sure that the Mpp can handle the 300ah.
Yes.
It could handle a 30,000Ah bank, but that would be overkill. The biggest consideration between inverter and battery size is if the inverter can properly charge FLA/AGM batteries at their 0.1C charge rate.
LFP can handle anything up to 0.5 - 1.0C depending on the cell ratings.
The Lion Safari 1300 batteries that I have are 12v nominal 105Ah, so four in series parallel would be 210Ah @ 24v. They are rated to discharge up to 150amps, but that is not the capacity.
