IMO: It Will Be Huge to see UL/CE certs on one of these All In Ones Options. I wonder who will be the first to do that, ... in an Always Evolving Arena of Ongoing Innovations . Likely cost a bit to jump that hoop with shifting requirements too.Surprised to see watts247 selling them before they've obtained UL/CE certs...
If you are considering a purchase, I recommend down load the specs to really compare. my impression: I think the LVX does have a higher PV input options. specs say of up to 450 voc (open cuircuit volts) and 120vdc -450vdc MPPT range. In contrast, a spec sheet I am looking at for the LV6548 says max 250Voc , and my LV2422 units max out at 145Voc :+)What are the major differences between the LV and LVX? Looks like the LVX has a higher Pv input?
SanTan Solar is saying these are now TUV/UL certified. https://store.santansolar.com/product/mpp-lvx6048-hybrid-inverter-split-phase-120-240vac-48v/IMO: It Will Be Huge to see UL/CE certs on one of these All In Ones Options. I wonder who will be the first to do that, ... in an Always Evolving Arena of Ongoing Innovations . Likely cost a bit to jump that hoop with shifting requirements too.
The LV6548 manual in section 4-2 goes over 3 phase operation.This unit is a modified European version to match USA voltages.
Unlike the LV6548, the LVX6048 is 240V Split Phase in one box.
The LVX6548 does not show or mention support for 3 phase.
Page 28
Grid-Tie Operation
6kW and 450V MPPT (100-400V range, 27amps)
9 can be stacked in parallel for as much as 54kW total output
The manual doesn't yet show the settings for USA (program 34, page 17)
The manual does show it feeding the grid.
View attachment 39076 View attachment 39077
MPP Solar Inc » SPLIT PHASE LVX SERIES – LVX6048
www.mppsolar.com
I think it is great to see: "compliant in regions that recognize this important safety standard." on that sell page. I would be surprise if that TUV/UL certification could get it past the hoop jumps in California for an approved Grid Tie, and thus official grid and electric supplier permission to feed the grid, and have an accounting of such on your utility bill. ... I will be open to being wrong; and would love to hear somebody getting fully grid tied in California with an LVX6048. I be dancing when I hear that story from a credible source :+)SanTan Solar is saying these are now TUV/UL certified. https://store.santansolar.com/product/mpp-lvx6048-hybrid-inverter-split-phase-120-240vac-48v/
You are correct. It is not listed as an approved inverter in California for grid tie. There is no MPP solar inverters on their approved list: https://www.energy.ca.gov/programs-and-topics/programs/solar-equipment-listsI think it is great to see: "compliant in regions that recognize this important safety standard." on that sell page. I would be surprise if that TUV/UL certification could get it past the hoop jumps in California for an approved Grid Tie, and thus official grid and electric supplier permission to feed the grid, and have an accounting of such on your utility bill. ... I will be open to being wrong; and would love to hear somebody getting fully grid tied in California with an LVX6048. I be dancing when I hear that story from a credible source :+)
Thanks Rhino! Appreciate the tip on the calculator.@Offgridmn You can use Midnite Solar's tool to check: http://www.midnitesolar.com/sizingTool/ and since we can easily have -40 temps up here on a nice sunny winter morning that calculator shows 12 of those panels in series at 330 Voc when it is -40 which is still ok for the LVX6048.
LV6548 is different than LVX6048The LV6548 manual in section 4-2 goes over 3 phase operation.
Yup. I was responding to your statement that the "LVX6548 does not show or mention support for 3 phase" I assumed you meant LV6548 and not LVX6048.LV6548 is different than LVX6048
I think I can answer the first two on the LV6548. Fans always on, but on low until a load.I sent an email to sales@usamppsolar.com asking 3 questions (and also see how good they are about responding to emails):
- Do the fans always run or are they temperature controlled?
- Do you know what the no load current draw is?
- Any idea if it would handle a 3HP electric motor?
