Bud Martin
Solar Wizard
- Aug 27, 2020
- 4,844
I am ready to buy one this small unit but something does not make sense to me about do not connect the solar panel first then the batteries (I am doing off grid setup) because it can damage the unit. I contact MPP Solar and they says the same thing. The thing is, you are supposed to install a fuse or breaker or disconnector between the batteries and the unit for protection, that means while the unit is running but the fuse/circuit breaker for the batteries is tripped it will then cause damage to the unit. So what is the use of having fuse/breaker/disconnector for the batteries, or Low batteries disconnect (done by the unit ) if it will damage the unit.
Can some one with the same unit please tell me if t hat is ture or not?
I watched Will's video (
) about this unit, the link to his website also shows the fuse for the batteries.
Thanks!
Thanks!
