MPPSolar LV6548 set up help
italianpianoman
I'm outfitting my tool trailer with a single MPPSolar LV6548 inverter.
My other equipment
- 4 silicate gel batteries (from Watts247), wired in series, using 2/0 cable, to make a single 250Ah, 48V bank.
- 3 Suntech panels - STP210-18/UB-1, (210W)
- 4 LG panels - LG315N1C-G4, (315W)
My questions:
1 - How do I connect my 7 mismatched panels correctly(best)? My assumption is 3 of the LG panels in series on one input and all the others in series on the other input. Thoughts?
2 - The inverter says I can use 4 AWG for the AC output side. Is a 70amp breaker the right size, if I add an electrical panel and run everything else from there? Could I go bigger?
3 - Since I'm using silicate gel batteries, I don't know if I need a shunt, a breaker, a fuse, or all three?? And how big, if I need any or all of them?
My other equipment
My questions:
Go ahead and try it that way, as long as you don't go over PV max Voc.
Usually I would go with a 60a breaker, 4 awg is usually considered an 85a wire, and observing the 80% rule, to size breaker 20% smaller. But you can look at the temp specs on your wire, and review an NEC wire ampacity chart to see if you can get away with a 70a breaker (I'm not going to look it up right now, so just providing some guidelines on things I check)... Remember, the breaker is to protect the circuit from overcurrent meltdown danger. But generally on all these LV6548s and 6500EX threads, I recommend a 60a breaker, I do have 4 of the LV6548s, and 60a is what I selected for the AC connections, since I am using 4 awg...
I don't know much about that battery chemistry, but I purchased a shunt (BMV-712) to have a more accurate measurement of my SoC (on my LV6548 system).
And remember that you still need a breaker or fuse on any wire / circuit runs to protect the cable and connectors from overcurrent. Some like fuses (like Class-T) due to faster blow protection, I am fine with breakers because they offer the convenience of a quick reset, and circuit disconnect.
